Door Lock buttons
Door Lock buttons
Has anybody come up with a fix for the door lock post on the front doors being painful to your arm when you put your arm on the window ledge when the window is down? I am sure I am not the only one this bothers....
Use the search box, plenty there..
But I removed the plastic knobs, trimmed the stems & re-installed.. flush in lock down.
I did leave the pass side a bit higher than flush, in case of emergency & no power..
Give this thread a try, you might find a mod that'll work for you.
https://www.chevyhhr.net/forums/show...t=lock+buttons
One thing to think about when doing this, the doors do not open from just pulling the handle like most cars. The doors have to be unlocked first, if the power door lock motor or switch or whatever doesn't work, you are stuck. LOL
Here is what I did. I hated the chrome and getting hit in the arm all the time.
I changed the rear ones too but left them the original length so if something happened and I needed to get out of the car with no power then I could open the rear doors.
Up
Down
Up
Down
RUDEINC
40
01-03-2008 07:54 AM
nfboy
06-27-2006 07:18 AM
cj krause
7
04-23-2006 09:02 AM
