Extra Key Fobs and Programming
Old 10-27-2006, 10:41 AM
RUDEINC's Avatar
Just as a heads up to everyone who doesn't know....If you ever purchase extra key fobs (keyless entry remotes) you have to have all of your remotes present in order to properly program them. For instance if you have 4 remotes total, you must have all 4 remotes there because they all need to be reprogrammed at once. I bought 2 extra remotes for spares, took them to the dealer to get them programmed, and while there I checked to make sure that they (new remotes) worked, and they did......But I didn't bother checking my originals, and when I got home and tried to lock the doors using my original remote and nothing happend. Then I went and got my wife's and nothing happend. So I called the Service Dept. where I went, explained the situation and I asked them if it was a possibility that all the remotes had to be there during the programming, and after a long pause............ their reply was....... I guess so......I find it funny that the service writer or the mechanic doing the reprogramming didn't even know this...Is the HHR the only vehicle that is like this? (I doubt it) Or is it possible that I'm the only person in the region that ever needed a remote programmed (I doubt it), or is it simply possible I'm dealing with idiots?.....
BTW at least they didn't charge me where I bought the car.. I called the dealer that is close to my house, and they wanted to charge me $60.00!! but maybe for the $60.00 it would have been done right and I wouldn't have had to go back twice......Now you know.....
RUDEINC is offline
Old 10-28-2006, 12:51 AM
TomsHHR's Avatar
Location: Superior, WI - Over the Hill Warranty Club member
Sounds like a garage door opener, you have to have them all there when you add more. If you get replacement keys you can program them yourself. I posted a thread on how to do that back in Nov 05.
TomsHHR is offline
Old Lar
06-01-2018 06:15 PM
HHRuss
01-20-2016 10:40 AM
Drcrazytrain
01-18-2015 12:56 PM
solman98
02-26-2009 10:49 AM
TomsHHR
South Central
08-08-2006 03:51 PM
Quick Reply: Extra Key Fobs and Programming
