Factory Undercoat
How odd that gm undercoated some and not others. I wonder what determined which ones they would do. I guess seeing that none of us are worrying about voiding a warranty, I might end up doing mine. Is it just the wheel wells that were factory undercoated?
Not from the factory, the ripoff finance department after sales. The only place they shoot is the wheel wells, where it can be seen. It doesn't do anything good, except maybe sound deadening.
GM says the type of paint they use is good enough for them to warranty rust through for (I think) 5 years. Some say undercoating hastens corrosion by locking moisture in and then concealing.
I think that the underbody is dipped in a wax concoction. Undercoating will not stick to it, causing bubbles for water to collect.
Underlying issue with undercoating: You shouldn't have bought it, but have dealer clean up his mess - tribunedigital-chicagotribune
And this from this forum the warranty booklet, make note the part about Alterations:
https://www.chevyhhr.net/forums/gene...-warranty-913/
I would certainly not add it without careful consideration of whether blocked drain holes will lead to increased rust, rather than the intended improvement.
If you have it already, it's no panic situation, especially if , like Fireman George, you never see salt.
Bottom line is, these dealer add-ons CAN void the GM Corrosion warranty, and this is why.
In my case, I am thinking of just hitting the fenderwell, may or may not use a little fluid film on the bottom inside edge of the of the doors, because my previous panel started to bubble and rust there. From what I can tell that is the only susceptible area that starts to rust out first.
Again, I don't think any of us have any warranty left...do we?
Blue SS, how you liking the blue flash? I switched from white to blue flash, really liking it, but the white hides everything, so I'm picking out every little flaw on the blue.
I have used "Rust Check" (only in Canada) and as of late "Krown" a local place in MI. Their process is more of a thick "oil" that they spray inside door seams and the under body. It seeps/wicks into all the cracks and seams. It doesn't block any of the weep holes, but is is kind of messy for a while after application. I have it done every other year or so, I really believe it's a good product. I think the last time I had my HHR sprayed it was $125.
I agree with a_bartle.
I im Ontario Canada, and our roads get salted like crazy and takes a toll on our cars for sure! I take it to "Krown" which soaks the hell out of the car in their oil which does an amazing job! Much better compared to "Rust Check" (they are a joke compared to Krown)
Id suggest getting it sprayed by Krown every year or every other year. Its about $100-130 depending on location. But well worth it! It does drip and cause a mess for a couple days, but I dont mind that since it does such a good job getting into all the crevices of the vehicle
goetylsd
18
07-24-2010 03:20 PM
