Fog light differences
Old 03-07-2017, 02:48 PM
Liquidh8's Avatar
Good afternoon all. My 07 LT doesn't have fog lights, I will be adding them factory style. My question is, what year should I use? The 07 seem to be just a regular old school lenses, and it appears the 08 up? are like a projector?
Any opinions? Thank you all!
Liquidh8 is offline
Old 03-07-2017, 08:45 PM
skyline26's Avatar
The SS came with the projector style fogs.
skyline26 is offline
Old 03-07-2017, 09:06 PM
Liquidh8's Avatar
Ahhh OK, thanks for the response. I assume the mounting is different on the SS versus the LS/LT?
Liquidh8 is offline
Old 03-08-2017, 11:59 AM
solman98's Avatar
FOr the LS and LT models, there were 2 different styles, one with a glare cap and one without. Both mount the same.
solman98 is offline
Old 03-08-2017, 12:19 PM
Liquidh8's Avatar
Thanks guys, I would like to get the overs that snap on the factory location. Rock Auto lists them.
Liquidh8 is offline
Old 03-08-2017, 01:07 PM
To avoid confusion and disappointment, I deleted the links
Oldblue is online now
Old 03-08-2017, 01:45 PM
Liquidh8's Avatar
Thank you! Now I'll post a want for the fog light switch.
Liquidh8 is offline
Old 03-08-2017, 04:40 PM
Technical Moderator
Do you know that you will need to program the BCM?
Have you looked at online GM parts stores?
https://www.gmpartsoutlet.net/auto-p.../switches-scat
https://www.gmpartsoutlet.net/auto-p...fog-lamps-scat
These will get you the part numbers, then you can plug them into eBay. Like this:
Fog Light Switch ACDelco GM Original Equipment 15933137 fits 08-11 Chevrolet HHR | eBay
And:
Driving Fog Lights Lamps Pair Set 15813307 15813308 for 06-11 Chevy HHR | eBay
Or check out some of the members that are parting out in the classifieds.
donbrew is offline
Old 03-08-2017, 05:06 PM
Liquidh8's Avatar
Donbrew, thanks for the links my friend. I just tossed on the tech2 and reprogrammed the BCM for fogs. As soon as I get the switch and lights it should work.
Liquidh8 is offline
Old 03-08-2017, 05:07 PM
Liquidh8's Avatar
Also, I have an 07, so the switch appears to be different? Not sure if the newer switch you posted would work, and how it mounts?
Liquidh8 is offline
Quick Reply: Fog light differences
