fog light install
fog light install
I have a 07 hhr that did not come with fog lights ,i have added aftermarket ones with a home made bracket but they are small and dont fill the hole and shake when driveing,i can get lights from dealer at 90 something apeice but no one seems to know how they are mounted in the hole,i think they snap in just like the blanks that were in the hole from the factory but can't get a for sure answer on it ,anyone on here know they mount?
They just snap in....like the plugs do....regards
see here........
https://www.chevyhhr.net/forums/how-tutorial-library-21/do-yourself-factory-fogs-637/
see here........
you might be able to find your answer in the "HOW TO" guide forum.
https://www.chevyhhr.net/forums/showthread.php?t=637
2008 hhr lt
my HHR was purchased used. It appears to have a customized front end with 4.5" diameter opening for fog lights. In checking the VIN with the dealer, it came with fog lights. After accessing the wheel well behind the bumper, there is nothing but the clean end of the hole or tube through the bumper. Is there a bracket for the lights to attach to?
Welcome to the site NP-Papa.
Did you read the posts above? Especially #2 where it says they just snap in.
Plus, read the links provided.
If you have a custom front fascia, then this may not apply to your car. Post up a picture of the front end for clarification if it's a custom piece.
