Front side left inside lock cable
Old 05-24-2015, 09:18 PM
des48's Avatar
Hi Guys I really need help big time. After reattaching cable to
door handle nothing appeared to be broken the cable end just
detached itself from the handle. I reattached the cable to the
handle . I put the door panel back on but the inside handle will not activate the lock. What else could have come undone while the door panel was flailing around ?? Thanks Dan
des48 is offline
Old 05-24-2015, 09:36 PM
Lucky's Avatar
There is a tsb that may help you it also has some pictures.
Look here and go to post #127 https://www.chevyhhr.net/forums/prob...-23231/page13/
Lucky is offline
Old 05-24-2015, 11:10 PM
des48's Avatar
Thank you Dan
des48 is offline
Old 05-24-2015, 11:12 PM
des48's Avatar
Thanks Lucky
des48 is offline
Old 05-25-2015, 01:04 PM
des48's Avatar
Lucky the pictures posted in the TSB thread are not for the 2011 or they are for the right side. Thanks Dan
des48 is offline
Old 05-25-2015, 01:10 PM
Technical Moderator
They should be "typical" . Do you mean yours does not look anything like that?
donbrew is online now
Stryker
12-08-2018 02:58 PM
des48
05-25-2015 01:10 PM
mo650chopper
19
03-22-2013 02:39 PM
2smokey
18
10-04-2010 09:17 PM
Quick Reply: Front side left inside lock cable
