help with water leak..
Old 05-09-2010, 12:06 PM
Former Sponsor
pyro panel's Avatar
a few weeks back noticed water on passenger floor...dealership found a leak in the door panel and repaired the seal..today..after a nasty downpoor and strong winds..soaked again..and alot of it too!!!thank you vince from sham wow..seems to be running down floorboards to me from the dash..anybody else have this problem????
pyro panel is offline
Old 05-09-2010, 12:47 PM
prod's Avatar
Common leak locations are the sunroof drain tube (if you have one) or the butyl rubber patch above the heater core. Unfortunately a few owners have had leak problems, so there are other threads here with more details.
prod is offline
Old 05-09-2010, 03:07 PM
I 'thought' they did away with that patch for 08 & newer ?
sleeper is offline
Old 05-09-2010, 11:51 PM
prod's Avatar
I know it was revised, not sure exactly what they did with it though.
prod is offline
Old 05-10-2010, 12:00 AM
hmmm. I don't know for sure either, but this link seems to have good info about it:
https://www.chevyhhr.net/forums/show...2water+leak%22
sleeper is offline
Old 05-10-2010, 04:15 AM
biglefthhr's Avatar
yesss driver side, no idea where its comming from drips out where the hood release is, I gave up on it. its not the driver door wire harness on mine!!!!
biglefthhr is offline
Old 05-10-2010, 09:32 AM
prod's Avatar
That one sounds like the sunroof drain tube is loose. Do you have a sunroof?
EDIT: I see you dont. In that case I would check the door seal close to the bottom corner of the windshield. Just a guess, but a lot of water goes down the trough on the leading edge of the door.
prod is offline
Old 05-10-2010, 05:43 PM
Former Sponsor
pyro panel's Avatar
no sunroof..seems to be at heater box..leak pro coming in tomorrow..gms guy..
Old 05-10-2010, 11:54 PM
Pyro-
Hope that all works out good for ya..Be curious what they find as the entry area.
sleeper
sleeper is offline
Old 05-11-2010, 03:28 PM
Former Sponsor
pyro panel's Avatar
well lets see how they did this time..leak pro found another spot by the heater box...i guess one of the seals was kinda "pinched and turned"..kinda same thing as the leak in the door...musta bin siesta time when mine came across the line...
Quick Reply: help with water leak..
