Interior door trim replacement
Hi all,
I know that remove the silver door trim on my 2010 HHR SS, i need to take the door panel off and then drill out the hot glue posts in the back.
While doing this I broke on of my trim pieces and wanted to see if anyone knew where I could order new ones? I've searched ebay and the web and I can't find just the silver strips.
If I have to order a set of 4 I will.
Thanks for your help!
Don't think you can get just the trim by itself. It's considered integral(part of) the door panel. You'll probably have to get a complete door panel.
Sounds like an expensive "oops" moment.
You might get lucky and find a used black SS door panel.
