LED Dome Light
Old 12-25-2006, 06:42 PM
billdaly's Avatar
LED Dome Light
Anyone have info on the ceiling led dome light above the shifter in '07 HHR's? I can't find anything in the book on it. It appears to come on with the headlights, is not dimmable, and you cannot turn it off.
billdaly is offline
Old 12-25-2006, 07:04 PM
captain howdy's Avatar
What info are you looking for? I replaced mine with a blue LED.
captain howdy is offline
Old 12-26-2006, 08:57 PM
nfboy's Avatar
It's to illuminate the window controls primarily. They are not backlit.
nfboy is offline
Old 12-27-2006, 02:20 PM
Desert Coyote's Avatar
That light is commonly called by dealers the "Mood Light." If you're looking to shut it off, you can't short of removing the LED or covering it up. Unless it's causing vision problems, it really isn't much of a nuisance (I actually kind of like it at night), and it's aimed carefully so as not to reflect off the windshield.
Desert Coyote is offline
Old 12-27-2006, 05:49 PM
SoCalHHR's Avatar
A small piece of tape works a treat if you want to "shut it off."
I'm betting in 2-3 weeks, you will just forget it's there like most of the rest of us.
SoCalHHR is offline
Old 12-27-2006, 05:53 PM
FIRETRUCKHHR06's Avatar
capt. where did you find a replacment led?
FIRETRUCKHHR06 is offline
Old 12-27-2006, 05:58 PM
SoCalHHR's Avatar
Radio shack has them in several colors.
Hope it helps,
SoCalHHR is offline
Old 12-27-2006, 07:19 PM
TomsHHR's Avatar
Location: Superior, WI - Over the Hill Warranty Club member
Welcome to the site Billdaly.. Some here get excited with repeat post, but everyone is friendly....
TomsHHR is offline
Old 12-27-2006, 08:09 PM
Radio Shack like SoCal said. It's a standard 5mm LED. Just make sure to get a high intensity LED so it's bright enough.
Old 12-27-2006, 08:11 PM
HHR Forever's Avatar
Theres dome lights in the HHR? Wow. I need to start noticing things.
HHR Forever is offline
Quick Reply: LED Dome Light
