Map lights won't turn off!
Old 07-15-2007, 09:03 PM
boswald's Avatar
Question Map lights won't turn off!
Has anyone has a problem with the map light on the rear view mirror not turning off. The buttons beside them do not turn them off. The car is off and locked and the lights are still on an hour after locking the car. I'm concerned that the battery will drain if I don't figure out how to turn them off.
boswald is offline
Old 07-15-2007, 09:07 PM
oneton's Avatar
CK the two bottons on the mirror to be sure they are off in is off, close the door and wait a min.or two see if they go off. Also is it a 07 the dimminer switch on the dash might be on also
"note" you can not make them go off if the door is open.
oneton is offline
Old 07-16-2007, 04:05 AM
Size:  5.6 KB to the site!!!
HillsdaleHHR is offline
Old 07-16-2007, 07:26 AM
Dan's HHR's Avatar
to the forum check carefully for buttons under mirror they are very little and may be confuse you
Dan's HHR is offline
Old 07-17-2007, 09:44 AM
boswald's Avatar
Thanks Oneton,
You were correct. I have the 2007 model and the dimmer switch was too turned too far to the right. Although there is a definite click on the switch, I must have had it just a little too far to the right and the reading lights stayed on. Thanks for the tip.
Bill
boswald is offline
Jeff®
09-06-2018 01:27 PM
shaunmcg
08-13-2013 06:27 PM
Blue Beast (aka Boydie)
Mods - Exterior
08-10-2013 09:18 PM
ClassicWalt
10-30-2007 06:39 PM
Quick Reply: Map lights won't turn off!
