Most Reliable Year of HHR? - Chevy HHR Network
Reply
LinkBack Thread Tools Search this Thread
Old 10-15-2012, 07:11 AM   #1
The HHR has been around now for about 8 years, so i was wondering if any one year or engine has emerged as the most reliable? Usually after a few years a pattern will emerge and a single year or two will be better than others, has enough time passed?
If your truck/car/suv has been reliable or has had lots of problems let us know the year mileage etc. Should be some interesting stories.
Drifter. is offline   Reply With Quote
Old 10-15-2012, 07:36 AM   #2
Images: 54
The HHR was made for 6 years, 06'-11'. Very few changes were made during the entire production run.
I doubt you will find that one year is that much more reliable than another.
Maybe the 06 had more bugs being the first year.
firemangeorge is offline   Reply With Quote
Old 10-15-2012, 08:21 AM   #3
db/sb's Avatar
Images: 12
Quote:
Originally Posted by firemangeorge View Post
I doubt you will find that one year is that much more reliable than another. Maybe the 06 had more bugs being the first year.
Our 06 has been what I'd refer to as reliable. We've had a couple of things repaired under warranty (shifter, catalytic converter/flex pipe), a couple of recalls but nothing out of pocket from the dealership. I've done brakes and front hubs, a timing belt and replaced the tires. Ours has just a shade under 70K miles. It seems to me that I hear more horror stories about the SS which didn't begin until 08.
db/sb is offline   Reply With Quote
Old 10-15-2012, 08:36 AM   #4
Images: 3
The SS was only made from 2008 to 2010. I really haven't heard of many major problems with them. Mine has 73K miles on it, and it's been routine maintenance items, plus new front swaybar drop links (fixed clunking) that were reasonable from AutoZone.
I don't think there are major differences between years otherwise. Some of the colors were only available for 1 or 2 years, though.
Blue_SS is offline   Reply With Quote
Old 10-15-2012, 08:38 AM   #5
solman98's Avatar
Images: 20
The 06 had some first year quirks that were indentified quick. Most, if all of those should be fixed by now. Not many changes/updates through the years.
Quote:
Originally Posted by db/sb View Post
a timing belt
If you paid to replaced a timing belt, you got robbed...... Ecotec's have a chain.
solman98 is offline   Reply With Quote
Old 10-15-2012, 09:23 AM   #6
db/sb's Avatar
Images: 12
Okay, okay...what I meant was a serpentine belt.
Old 10-15-2012, 10:57 AM   #7
I have an 08 SS with 81K miles on it, and have had basically zero issues with it. There were a few owners that had problems with the turbo, mostly related to the connections failing. I think most of the problems were with the 5-speed as opposed to the automatic.
What's amazing is that I get a very powerful performance AND I can get close to 30 MPG on the highway. It's an amazing combination.
jerSSey HHR is offline   Reply With Quote
Old 10-15-2012, 02:46 PM   #8
Images: 18
My 06 1LT 2.4L auto turned 101,000 recently. Brakes replaced at 92K, shocks at 62K, key stuck in switch under warrenty in 06. Other maintenance battery, turn signal light bulb and some tires (third set) and a couple of wheel alighments..
Old Lar is offline   Reply With Quote
Old 10-15-2012, 03:53 PM   #9
badassbowtie's Avatar
Images: 201
I would say that any significant "bugs" would have been worked out with the cobalt(same delta platform) in 05...I have had a 06 cobalt, 07 hhr lt, and 08 hhr ss...all have been awesome, and taken a beating at times
badassbowtie is offline   Reply With Quote
Old 10-15-2012, 06:09 PM   #10
Images: 3
The answer "Should Be" 2011's as all the updates and upgrades are usually in the last year of production.
Unfortunately it is still somewhat a car by car basis based on how lucky you are.
Just look at the Steering Column issue as an example. I'm not sure if they actually ever got the fixed replacement Parts into the late model 2011 production.
The 2010 still had the Column issue as early as 15-17,000 miles.
It also still had an ignition switch recall too.
SF
Silverfox is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
reliable xeon light kit hhr_2009 General HHR 1 05-18-2013 08:28 PM
Just how reliable are battery tests? RICK167448 Maintenance and Upkeep 14 04-25-2011 08:41 PM
10 Most Reliable Cars (MSN Money) Snoopy The Lounge 9 12-17-2010 03:21 PM
HHR, How reliable is this thing? BigBear45 General HHR 32 07-26-2009 01:43 AM
are these turbo motors reliable??? chooch HHR SS 21 02-12-2008 03:49 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
