Motor Oil weight - Chevy HHR Network
Reply
LinkBack Thread Tools Search this Thread
Old 06-09-2009, 10:32 AM   #1
Motor Oil weight
I know the recommended oil is 5w 30. Is there any problem with using 5w 20?
Jim
jcgc50 is offline   Reply With Quote
Old 06-09-2009, 10:39 AM   #2
oneton's Avatar
Images: 33
IMHO I think 5/20 in florida in the summer is a little lite.
oneton is offline   Reply With Quote
Old 06-09-2009, 10:56 AM   #3
ChevyMgr's Avatar
Images: 707
Quote:
Jim
Only problem is it's not recommended to use it.
ChevyMgr is offline   Reply With Quote
Old 06-09-2009, 12:07 PM   #4
Quote:
Actually, I picked up the wrong weight by mistake and that prompted this post. I think I will take it back and pick up the recommended weight. Maybe at 10,000 miles will go ahead and switch to Mobil 1 anyway.
Thanks for the responses.
Jim
Old 06-16-2009, 07:16 AM   #5
oil
Personally, I use AMSOIL synthetics. They have three grades (prices too) to choose from. They range from 7,500 mile oil change interval to 25,000 mile intervals. Cost is a lot less when you consider the less frequent change of oil. Second, and most important is that this synthetic formula reduces friction and therefore parasitic loss, improving fuel economy in the 5% to 10% range. Worth it for that alone! Also good on cold start. More oil on the top end than conventional oil.
Oh yes, I sell it too.
Paul
sfttailpaul is offline   Reply With Quote
Old 09-19-2009, 08:42 PM   #6
Changed to Mobil 1 5w 30 at first change am thinking of going to Mobil 1 10w 30 being in Alabama don't have the intense cold. So should offer more protection. What say you all?
jbman is offline   Reply With Quote
Old 09-19-2009, 08:49 PM   #7
Images: 325
Well, there are plenty of threads he can find as to what type of oil we all use...
I would say return it, especially if your engine is relatively new, and get the recommended.
urbexHHR is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
Can the Ecotec LTG (Gen 3) motor be used to replace the LNF (Gen 2) motor in my 08 SS todman2 HHR SS 8 01-01-2015 10:54 AM
Weight of oil ?? 06burntorange Maintenance and Upkeep 22 11-12-2013 11:31 PM
thinking of putting a motor in the truck to tow is that to much weight? 2smokey Brakes | Suspension | Shocks | Struts 14 01-14-2011 04:42 PM
Zero weight oil ??? catdaddy137 General HHR 13 04-04-2009 10:21 PM
More Weight = Better MPG???? bisho1p 2.2L Performance Tech 14 07-18-2007 07:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
