Power Window Switch
Power Window Switch
I discovered that both of my rear view windows will roll down but neither back up. There is no funny noise or anything like that. I can roll them up from the main driver console and I've removed the door panel and unplugged and replugged the switch so I'm thinking the switch has bad contacts or something. Has anyone ever had the problem? I'm calling Monday to see if that part of the car is still under warranty.
You did check the window lock button, I assUme? It would be very embarrassing for the shop to simply push a button and charge you $79.
3yr/36,000mi on most cars (it would be in your books in the glovebox).
