Pulsating brakes
Pulsating brakes
I have a pulsating brake problem in my '06 HHR, which persists even after I replaced front rotors and disc brake pads. Where else should I look? Could it be steering? Or wheel balance?
Rear brakes, LCA bushings, ball joints, struts.
Is the pedal actually moving up/down, or, is the car shuddering on braking?
This is probably the most posted problem on this site. You might try search and read about other peoples solutions.
Welcome to the site! A shake in the steering wheel whilst braking, most likely worn out lower control arm bushings or LCA bushings. I suggest you get a pair of Moog K200792 problem solvers, like the one on the left, the bushing on the right was the second OEM bushing.
Also double check the inner and outer tierod ends and ball joints!
What about the lower steering shaft ? Don't you have a picture of that part ?
Doc brown
26
05-28-2014 08:17 PM
Oldblue
11-24-2013 11:18 AM
mrarff
0
01-07-2011 08:15 AM
