Rear Power Outlet
Does your front one work? There isn't a switch I know of, just used mine the other day with no prob. If the front isn't working I would bet on the fuse, but maybe a wire came loose if the console has ever been pulled out too.
I plug my cell phone charger in the rear outlet occasionally because I can leave it in the car and you can't see it through the dark windows. It has worked fine for me. My boys have used a converter to plug in their laptops and it worked for that also.
what i recomend to everyone is pry off the cup holder console starting from the rear (back seats). when i took mine off to paint (later pics posting) i noticed that my power outlet was not even plugged...****! it didn't even have a wire running to it...like it was just there for looks. taking off the cup holder console is not that hard of a job, it just snaps off and right back on. check it out and give it a look see
ok i checked the connection for the outlet underneath the rear cupholder, and checked the fuse and both are fine. There's a 15A fuse in it's place, when the fuse box cover reads "20A" for that location--- does the fuse size make a difference? The outlet still isn't working.
Thanks!
Thanks!
Thanks!
Thanks!
