Replacing front seats
So I've been looking to swap out cloth for leather (fronts only...for a panel) and I think I located a set nearby. A few questions.
Are all years interchangeable?
Can I just remove the seat back and bottom and reuse my original frame etc.?
If the new seats are heated, can I hook that up if I swap out the controls and what's involved?
Thanks.
Thanks.
Manual seat to manual seat they fit no problems
Power seat to manual seat , now the frames and covers are different
Adding the heaters, you will require the heated seat switches and control module
https://www.chevyhhr.net/forums/mods...ats-help-4157/
When you say heated seat switchs and control module, are those both on the console below radio?
So in other words, if I get the seats and the switches on the console, am I good to go? Thanks OB
That link is not very helpful, but try the search tool, it's been done several times and I believe instructions are in here somewhere.
Was it firemangeorge?
As far as I know, the mounting is identical across the years.
He's the wiring guru right. I would think its pretty straight forward, just wanna make sure. Guess if I couldn't get it hooked up wouldnt do any harm. Right. But if its simple, I'd give it a shot.
