RPO Code lists (Options) - Chevy HHR Network
Reply
Thread Tools Search this Thread
Old 01-15-2008, 07:33 AM   #1
Inside the glove compartment of the HHR, there is a tab showing all the factory build codes for the equipment and options on that particular vehicle.
Does anyone have a reference that details the contents of these codes ?
ralphb is offline   Reply With Quote
Old 01-15-2008, 11:59 AM   #2
Images: 3
From the Edmonds.com site you can find this when you do a price with options, seems there are some threads out there on the forum also. http://www.edmunds.com/new/2008/chev...n=1&x=116&y=14
KBB.com http://www.kbb.com/KBB/NewCars/Optio...ng&YearId=2008
an08HHR is offline   Reply With Quote
Old 01-15-2008, 12:22 PM   #3
Snoopy's Avatar
I think, the original poster should request this as a "stickey". Questions come up frequently regarding an option and build code.
Snoopy is offline   Reply With Quote
Old 01-15-2008, 02:51 PM   #4
I believe that my question was misunderstood. I don't mean ordering codes for a new vehicle. (Although some of the codes are the same as the codes used for ordering)
The codes I am talking about are build codes that show all factory items that were installed on the car, such as :
Type of transmission; Axle final drive gear ratio; Rear sway bar; Brake system, Seats; Interior color code,etc. It shows the paint code for the exterior, and what type of paint was used. It breaks down every item that would have been a choice for a worker on the assembly line. There are about 50 such codes listed on my 2008 HHR SS, most of them being 3 digit alpha numeric codes. It is much more extensive and inclusive than the codes used by a dealer ordering a new vehicle.
I have seen these codes for older GM products, but I don't know where to find a listing of the codes for current products.
Old 01-15-2008, 03:13 PM   #5
Images: 247
The following thread may be what you're looking for........
http://chevyhhr.net/forums/showthread.php?t=10645
I know it says for 2008 RPO codes but many are the same as my 06.
jx3 is offline   Reply With Quote
Old 01-16-2008, 02:01 PM   #6
This is great !
It has some of the SS codes, but not all of them. Apparently, it has not been updated.
Old 07-30-2008, 05:01 PM   #7
Images: 3
Anyone find an RPO code list for the 2007 HHR?
Norsican is offline   Reply With Quote
Old 07-31-2008, 03:12 PM   #8
Retrorod's Avatar
My RPO code list is old, I've contacted my sources (as a Dealer Service Manager) and requested an update RPO list.
Retrorod is offline   Reply With Quote
Old 08-01-2008, 10:00 AM   #9
ChevyMgr's Avatar
Images: 707
2007
2007 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1757267
________________________________________
RPO Code List
RPO Description
AJ6 Adjuster - Seat, Power, 6-way, Vert, Driver
AL0 Sensor Indicator - Inflatable Restraint, FRT Pass/Child Presence Detector
AP3 Lock Control, Entry - Remote, Keyless Entry, Start
AR9 Seat - FRT BKT, Deluxe
ASF Restraint Roof Side, LH and RH, Inflatable
ATY Seat RR - Not Installed (Seat Belts, Labels, MTG Hardware)
AXP VIN Ident - Position, Multi-Purpose Vehicle
BVE Steps, Runningboard, Side
B36 Covering - Floor Mat, Luggage Compartment
B57 Ornamentation - EXTR, Deluxe
CF5 Roof - Sun, Glass, Sliding, Electric
CV3 Country - Mexico
C2Y GVW Rating - 4,240 lbs
C67 HVAC System - Air Conditioner FRT, Electronic Controls
DD8 Mirror I/S R/V - LT Sensitive
DG7 Mirror O/S - LH and RH, Remote Control, Electric, Color
DT4 Ashtray - Cigarette Lighter
D22 Mirror O/S - LH and RH, Remote Control, Electric
FE1 Suspension System - Soft Ride
FE3 Suspension System - Sport
FE9 Certification - Emission, Federal
FR8 Ratio - Transaxle Final Drive 4.17
FX2 Ratio - Transaxle Final Drive 3.91
G63 Provisions - Luggage Carrier, Roof
JM4 Brake System - PWR, FRT Disc, RR Drum, Cast Iron, Antilock FRT and RR WHL
J41 Brake System - PWR, FRT Disc, RR Drum, Cast Iron
KA1 Heater - Seat, FRT
K05 Heater Engine - Block
LE5 Engine - Gas, 4 Cyl, 2.4L, MFI, Alum, DOHC, HO, ECOTEC
L61 Engine - Gas, 4 Cyl, 2.2L, MFI, Alum, DOHC
MM5 Merchandised Trans - Auto Provisions, O/D
MN5 Transmission - Auto 4 SPD, HMD, 4T45-E
MX0 Merchandised Trans - Auto Provisions, O/D
M86 Transmission - MAN 5 SPD, GETRAG, 5T45-E, M, F23, 75MM, 3.58 1st, 2.02 2nd, 1.35 3rd, 0.98 4th, 0.69 5th
NE1 Certification - Emission, Geographically Restricted Registration for Vehicles up to 14,000 lbs, GVW (Use 2003 Mdl Yr)
NF4 Emission System - Clean Fuel Fleet
NP5 Steering Wheel - Leather Wrapped
NT7 Emission System - Federal, Tier 2
NU1 Emission System - California, Lev 2
NW7 Traction Control - Powertrain Management Only
N24 Steering Wheel - Plastic, 3 Spokes
N85 Wheel - 17 X 6.5, Aluminum
QBV Tire All - P215/50R17-90S BW ST TL AL2
QB5 Wheel - 16 X 6.5, Steel
QDB Tire All - P215/55R16-91S BW R/PE ST TL AL2
QDJ Tire All - P215/55R16-91H BW R/PE ST TL AL3
QG9 Wheel - 16 X 6.5, Aluminum, Machined Face
QP2 Wheel - 17 X 6.5, Aluminum Polished
Q8H Mud Flaps - FRT and RR, Formed
SAL Plant Code - Ramos Arizpe, Mexico
T37 Lamp - Fog, Deluxe
T62 Lamp System - Daytime Running - Delete
UE0 Communication System - Vehicle, G.P.S. - Not Installed
UE1 Communication System - Vehicle, G.P.S. 1
UQ3 Speaker System - Enhanced Audio
US8 Radio - AM/FM Stereo, Seek/Scan, CD, Auto Tone, Clock, ETR, MP3, RDS
US9 Radio - AM/FM Stereo, Seek/Scan, RDS, Multiple Compact Disc, Auto Tone Control, Clock, ETR, MP3
UW5 Speaker System - 6, Base
U1C Radio - AM/FM Stereo, Seek/Scan, CD, Clock, ETR
U2K Digital Audio System - S-Band
U19 Speedometer, Inst, Kilo and Miles, Kilo Odometer
VPM Modification - Noise Control, Mexico
VK3 License Plate Front - FRT Mounting Pkg
VY7 Knob - Trans Control Lever, Leather
V73 Vehicle Statement - Delete
V78 Vehicle Statement - Delete
YF5 Certification - Emission, California
Z49 Export - Canadian Modif Mandatory Base Equip
1LS Package - LS Option 1
1LT Package - LT Option 1
2LT Package - LT Option 2
ChevyMgr is offline   Reply With Quote
Old 08-01-2008, 10:05 AM   #10
ChevyMgr's Avatar
Images: 707
2008
2008 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1905453
RPO Code List
RPO Description
AT8 Restraint Provisions - Child, RR Seat, RR Facing
AXS VIN Ident - Panel Van
CW4 Country - Caribbean (Antigua, Antille, Bahama, Barbados, Bermudacayman, Dominican, Haiti, Jamaica, Nassau, S.M. Trinid)
CZ1 Country - Central America (Belize, Costa Rica, El Salvador, Guatemala, Honduras, Nicaragua, Panama)
D48 Mirror O/S - LH and RH, Remote Control, Electric, Color
D81 Spoiler - RR, Aero Wing
EXP Export
FE5 Suspension System - Ride, Handling, Performance
FQ7 Ratio - Transaxle Final Drive 4.05
FR9 Ratio - Transaxle Final Driver 3.29
G85 Axle - Limited Slip, FWD
JL4 Control - Active Brake
JL9 Brake System - PWR, FRT Disc, RR Drum, Cast Iron, Antilock, FRT and RR WHL
IPB Trim - Interior Design (PB)
IP2 Trim - Interior Design (P2)
LNF Engine - Gas, 4 Cyl, 2.0L, DI, Alum, DOHC, TURBO, GM
MU3 Transmission - Man 5 Spd, SAAB, 76.5 mm, 3.38 1st, 0.70 5th
M86 Transmission - MAN 5 SPD, GETRAG, 5T45-E, M, F23, 75 mm, 3.58 1st, 2.02 2nd, 1.35 3rd, 0.98 4th, 0.69 5th
NU2 Emission System - California, ULEV2
NZ6 Wheel - 16 X 6.5, Steel, High Vent
PZ4 Wheel - 18 X 7.5 Aluminum, Polished
TBD Tire All - P225/45R18 AL3 All Season
T43 Spoiler - RR
T96 Lamp - Fog, FRT
VGG Protector - RR Bumper
VT7 Owners Manual - English Language
Z49 Export - Canadian Modify Mandatory Base Equip
Reply
Thread Thread Starter Forum Replies Last Post
P2A01 Code After New Cat Installed for P0420 Code NxlKing2304 Problems/Service/Repairs 15 02-14-2014 07:41 AM
P300 code yesterday, 420 code today. edgarfrog Problems/Service/Repairs 8 10-25-2013 08:43 AM
p1174 code and misfire code LtGhost08 Problems/Service/Repairs 4 06-10-2013 02:13 PM
Which are your options? Zagohhr Mods - Exterior 0 10-13-2011 09:46 PM
HHR Grille Options - Wheel Options VersysRider Mods - Exterior 12 02-23-2011 01:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
