Sunroof functions
Fireman.......
Are you saying when you engage the tilt button your sunroof window tilts about 3 inches?
Strange, mine only tilts about 1 inch (roof line to window). But I thought ORIGINALLY mine tilted more than that. I asked a question on the forum about that several months ago. I thought MAYBE I did something to the mechanism when I removed the headliner and repaired the windscreen.
But to the OP.....mine just tilts directly to that position. It does not rise an additional height then lower, to the 1 inch.
Fireman.......
So this is my sunroof in the tilt position. Just barely high enough to allow air in.
And this is a short video of when the roof is "tilted" and I hold the tilt button for a few seconds. I am not hitting the button a second time to lower the glass, it does this on its own.
https://www.dropbox.com/s/g2o5tl8yr5...2019.02.25.mp4
SOLVED THE PROBLEM! It seems as if the vent function seemed to have lost its positioning, which is the reason I could raise it to two different heights as shown in the video. All I did to remedy the problem was vent the glass open, and then press and hold the vent button to open again for 20-30 seconds. I then closed the sunroof and pressed the vent button one more time to open, and the glass raised to the 2-3 inch height that it should of been at all along! I'm very glad I didn't have to take it to the dealership.
Hmmmmmm.....
Now you have me wondering. If I do the same procedure, will my vent open wider than the 1 inch it now opens. First chance I get, I'll try it.
Glad you got it corrected also.
nacorona
07-10-2011 04:24 AM
