Towing a 2009 HHR w/Automatic Transmission
#33
#35
Hmmm. Unless I'm reading it wrong, my owners manual says it is OK to dolly tow.
This from the manual:
Use the following procedure to dolly tow the vehicle from the front with two wheels on the ground: 1. Put the front wheels on a dolly. 2. Move the shift lever to P (Park). 3. Set the parking brake and then remove the key. 4. Clamp the steering wheel in a straight-ahead position with a clamping device designed for towing. 5. Secure the vehicle to the dolly. 6. Release the parking brake.
#36
Dolly Towing
Your vehicle cannot be dolly towed, but can be dinghy
towed. See “Dinghy Towing” earlier in this section.
Notice: Dolly towing your vehicle may cause
damage because of reduced ground clearance.
Always tow your vehicle using the dinghy towing
procedure listed in this section or put your vehicle
on a flatbed truck.
#39
Since the HHR is a FWD car and the rear wheels just spin, there is nothing in the world to keep you from using a dolly. In fact, if you don't want to install a towing package on the front of your car, it is the only way short of a flatbed.
I would love to know the owner's manual author's reason for writing that. It makes zero logical sense.
Ahh, now I see George has found the correct entry. Knew it.
#40
It seems the General can't make up its mind. Some manuals read like that, some like this.
Dolly Towing
on a flatbed truck.
Dolly Towing
on a flatbed truck.
