Towing small camper
Old 05-27-2007, 08:55 PM
HonestBlues's Avatar
Been looking at Teardrop trailers myself and found this site.The weights are within towing capacity and the Retro look is cool.Just an idea for those who might be interested. http://www.golittleguy.com/ EDIT...If I had read back through the thread I would have seen Angelo's post,DOH!! ...but still worth a look.
HonestBlues is offline
Old 05-27-2007, 10:16 PM
Thylacine's Avatar
Very cool little campers.
Thylacine is offline
Old 05-27-2007, 10:41 PM
mitzkity's Avatar
I would KILL for a teardrop!!! They are pretty darned expensive, though, aren't they? And approx how much to get a hitch installed?
mitzkity is offline
Old 05-28-2007, 09:47 AM
SandyBeach's Avatar
Another thing you need to consider is the drag while pulling a pop-up trailer. The width of the HHR is only 69" and most trailers are probably 76" or greater. That means the wind will be running into that front wall of the camper causing much more drag and greater controllability problems. Not a situation I want to tackle!
SandyBeach is offline
Old 05-28-2007, 10:07 AM
SindyDix's Avatar
A couple of our members have motorcycle trailers. Here is one. I'm unable to locate the other one.
https://www.chevyhhr.net/forums/show...rcycle+trailer
SindyDix is offline
Old 05-28-2007, 02:02 PM
  #26
rjd222's Avatar
https://www.chevyhhr.net/gallery/fil...un2600x400.jpg
Here is a photo of my setup towing a small open trailer & my Harley. I'm taking a trip up north with several stops on the way. Just me & my RC models & the usual clothes.
I made the 1st stop in Virginia & had no problems at all. I kept it at a reasonable speed & she just rolled along fine.
The next stop will be maryland,then PA, then NJ, & finally CT. I'll try to post the results as I go along for those that might be interested.
If the URL dosnt work for the photo, just go to my gallery & it is there.
Ralph
rjd222 is offline
Old 05-28-2007, 03:11 PM
  #27
TomsHHR's Avatar
Location: Superior, WI - Over the Hill Warranty Club member
I am thinking about a lighter trailer to pull my atv with removable ramps or a tilt. My Honda Foreman is 495 lb and the trailer is around 325. I only pull this 120 miles at a time between the GF's and my place but I have one grade I still do not like going up or down and I want to drop the ramp drag on mine.. I am looking into a cooler and would suggest that for any long pulls.
TomsHHR is offline
Old 05-28-2007, 04:05 PM
  #28
Rrailwriter's Avatar
Seems like a motorcycle trailer would be pretty good to pull. Some of those motorcycle trailers turn into pretty big camping areas. I've seen some that open and set up in just seven seconds. I'll have to see if I can find the site so I can post it.
Rrailwriter is offline
Old 05-28-2007, 06:51 PM
  #29
You can install your own hitch with plug-in wire harness in an afternoon.The cost of hitch and wiring should not be more than $150 total.Here is a link to a seller I will soon do business with: http://stores.ebay.com/LWM-Transportation-Enhancement http://cgi.ebay.com/ebaymotors/ws/eB...2834425&rd=1,1
Old 05-28-2007, 07:20 PM
  #30
killerhhr's Avatar
trailering
I have been pulling a trailer all over the U.S for about 40000 miles.It is 5x8 trailer ,I haul 2 -10 x20 tent on it and tables.In the back of the car I have all my paints and thinners.I drive it to carshows all over and still get around 29 mpg.1000lbs is a butch of BS,It will pull more than that.
killerhhr is offline
Quick Reply: Towing small camper
