turn signal bulb replacement
Len just reach in grab the bulb holder and rotate it to the left as if you were unscrewing a bolt. It will turn about a 1/4 turn and the bulb and socket come right out.
There are no wires to disconnect. Remove dead bulb, insert new bulb, push back in same position and then rotate to the right and it will lock in.
Mike
Mike
Well folks. Here's a video for those that need it.
Only reason I could see for needing pliers is if the glass bulb was shattered.
A FYI. Always a good practice to NOT touch the glass part of any automotive bulb with a bare hand. At the least, wipe the bulb glass clean with an alcohol prep before completing the installation.
