HHR Panel production numbers?
Hi i have seen people asking what production numbers were for HHR panel SS?. But i want to know what just the LS panel numbers were preferably by years if not available here where can i get them?, and how do you identify a plain jane panel,or window model, from a SS model? i'm sure its in the Vin number but specifically were is it designated? thanks
Did you try a search here for production numbers ? There are several old threads with numbers and breakdowns by model.
To tell the differences between models, it's easier to go by the RPO codes tag in the glovebox. The SS is the only model that had the FE5 code for the suspension it came with. LS was FE1. 1LT and 2LT was either FE1 or FE3.
The vin for the SS will have a "M" for the 2.0L SS only engine size. (can't remember if it's 8th or 10th digit in the vin)
By looking at the front bumper the SS does not have the horns and you can see the intercooler through the lower hole. The grille only has one cross bar.
Actually, it is an "X" in the eighth position of the VIN.
See firemangeorge's sig.
