Odometer Not advancing
Old 04-20-2018, 10:52 AM
hotwireflyer's Avatar
Hi, This is my 1st post here, I have been lurking the forums for 4-5 years, Just purchase our 2nd HHR, a 2011 and may have an issue. Purchased with an oil leak, found it to be the crankcase leaking, R&Red the engine (thru the top) and resealed the crankcase, runs fine no leak, finally drove it and noticed that the Odometer has not gained any miles. Everything else on the instrument cluster works correctly. Has it been hacked? Any GM techs here that have seen this issue before? Local dealer admits to no previous experience. Hope someone has some experience. Thanks. Steve
hotwireflyer is offline
Old 04-20-2018, 01:41 PM
Technical Moderator
The BCM stores the odometer data and sends it to the I/P via serial data.
A GM dealer should be able to tell if the 2 readings agree. If it has been hacked the DMV will get involved, they can tell when it was done since it is a requirement to record the odometer reading upon sale. California has big time enforcement on odometers and the Feds too.
I bet the instrument panel was replaced by an amateur. The VIN needs to be updated.
donbrew is offline
Old 04-21-2018, 07:57 PM
Thanks for the info Donbrew. BTW where is the posted info from?
Old 04-21-2018, 09:42 PM
Technical Moderator
The shop manual.
donbrew is offline
Old 04-24-2018, 09:24 AM
Dos it say how to fix the issue?
Old 04-24-2018, 10:22 AM
Technical Moderator
With a Tech2 or similar that can read and write ti the IPC, I guess it does not say.
However, I bet it is illegal to sell the car in that condition. The DMV gets touchy about odometer cheating. In some instances you need certificates to change an IPC that stores the odo data, on HHR it is stored in the BCM.
donbrew is offline
Old 04-24-2018, 08:22 PM
That is why I took it to the dealer, Need it to work correctly. Hopefully we will see what the correct mileage is, and then act accordingly. Thanks for your help.
BTW, Do we know any good GM techs in Southern California? Thanks
Old 04-26-2018, 01:15 PM
Do we know any good GM specialist in Southern California??? I could use a referral...
pkt1213
06-02-2014 01:04 PM
HillsdaleHHR
58
04-30-2009 05:54 AM
mongo
08-30-2008 12:26 PM
guppyfry
07-29-2008 07:31 PM
Goose
06-04-2007 09:25 PM
Quick Reply: Odometer Not advancing
