Key Stuck In Ignition Warrenty Extention - Not a recall #14632
#72
#73
Some do and some don't. But in my opinion and in this instance, if you are experiencing EVERYTHING THAT I OUTLINED, it is a separate issue and should be repaired without charge.
This special Customer Satisfaction repair that I am speaking of should be attached to your VIN and the dealer should be able to see it on the GM vehicle information system......and NO CHARGE.
#75
That's the plan....Only thing is, it hasn't happened since posting. But likely will when I least expect it.
Dealer said it was illegal to fix something else on my ride while I have a TPMS light on from a dead sensor battery, said they must fix that first. No way would I pay $90. per sensor there + labor.
#76
Then buy a set off RockAuto and have your local shop install them!
https://www.rockauto.com/en/catalog/...)+sensor,12036
don’t forget the discount code!
