Back in the shop
Old 09-03-2010, 01:53 AM
rice trax's Avatar
Back in the shop
I just picked up an 08 ss with 29k. Had to take it back 3 times within 2 weeks already for hesitation problems. The first time they said it was due to getting some connections wet while detailing. Next they said it was due to an oily k&n filter and now after they could not find anything wrong after testing it for 2 days. I will be picking it up tomorrow. Any advice on what would be the problem?
rice trax is offline
Old 09-03-2010, 07:44 AM
bartSS's Avatar
Do you have the stage kit installed?
bartSS is offline
Old 09-03-2010, 03:53 PM
rice trax's Avatar
no stage kit to my knowledge. Is there a way to check this?
Old 09-03-2010, 04:15 PM
russruth's Avatar
The dealer should be able to tell, take it to finley chevrolet, they're good.
Also when your there have them check the fuel pump. Lost mine 59 miles from Vegas and I think part of the reason was it was 106F outside.
Just a guess, but worth a look.
J.
russruth is offline
Old 09-04-2010, 11:13 AM
asanti's Avatar
Easiest way to tell if your SS has an upgrade is the sensor at the top of the intake mani in front of the engine, it should have a blue Bosch sticker IIRC (haven't been under the hood in mine in a bit). Also you'll have a carb sticker under the hood, and the fuel sticker on the gas door should say "premium fuel only".
Later
Allex
asanti is offline
Old 09-04-2010, 02:48 PM
redradt25's Avatar
Where did you pick up your HHR?
redradt25 is offline
Old 09-04-2010, 02:59 PM
rice trax's Avatar
I just got the car back and it is working fine so far. The service guy said that they did not find anything wrong but did some updates to the computer. I also checked for the upgrade and found the bosch sticker. Yeah!!
Thanks for all the info
Old 09-04-2010, 03:00 PM
rice trax's Avatar
Got it at henderson chevrolet in las vegas
Cadha13
08-21-2011 05:55 PM
LolaIsMyHHR
05-19-2010 01:47 PM
JJ's BLACK SS
03-04-2010 08:11 PM
Scrivs
11-15-2009 02:57 PM
MrHHR
03-25-2009 05:43 PM
Quick Reply: Back in the shop
