Engine Diagrams
Old 03-19-2008, 05:20 PM
Cpt.Carnage's Avatar
Engine Diagrams
Was at work the other day and managed to grab a copy of the engine breakdown from our GM Parts server. This is the exhaust side of the engine including the turbo. Sorry bout the small picture size but they are limited If you want a high res version ask and ill post a link.
Moved the links up for easy access:
http://rapidshare.com/files/100841457/HHRSS.zip.html
http://rapidshare.com/files/10131220...HHRSS.zip.html
Cpt.Carnage is offline
Old 03-19-2008, 05:22 PM
And heres the intake side
Old 03-19-2008, 06:10 PM
turbofreak's Avatar
Yes, would like hires versions of both sides and ;arts list too if u have it.
Thanks for posting.
turbofreak
Last edited by HillsdaleHHR; 03-19-2008 at 06:11 PM. Reason: Removed image from quote
turbofreak is offline
Old 03-19-2008, 06:33 PM
I figured someone would want them, heres a rapidshare link to a zip w/pdf's in it. All parts are numbered and given there RO#'s. This is pretty much everything in the engine compartment.
Old 03-19-2008, 07:02 PM
LT1GMC's Avatar
THANK YOU!! Those are great!
LT1GMC is offline
Old 03-19-2008, 07:26 PM
I can take requests if you guys want more sections. The only really good part I can think of is the wiring harness and electrical for the dash, would anyone want those?
I got these for my self, have a black SS on order due in any day now and I figured people would be able to use them.
Old 03-19-2008, 08:46 PM
turbofreak's Avatar
A big THANK YOU for these!! Printed them out allready.
I can think of 2 areas that would be nice. The first is the wiring for boost gauge which appears to be a gauge run by pcm from MAP sensor, not a "real"
gauge. The 2nd would be something showing the pinout to the PCM showing
what ea pin is. Suspect is same as GXP.
Thanks again.
turbofreak
Old 03-19-2008, 08:57 PM
Well ill check the diagrams on the system tomorrow, only problem is its a parts program so it will list items, not sure about electrical diagrams. May need to dig into this.
Old 03-21-2008, 03:05 PM
Got some more diagrams, mainly the turbo and fuel system. It also has a detailed breakdown of the dash w/all part numbers so you can get extra dash pieces if needed. See the first post for links
Old 03-21-2008, 07:52 PM
turbofreak's Avatar
Again a big thank you for these diagrams. This is info hard to find even if u
have a service manual which is not ready yet from Helm so this info is even
more important for those of us who are "playing" with their cars.
turbofreak
oceangoer
04-19-2015 10:16 PM
chevhhrdummy
09-30-2014 07:48 PM
pwhitie
09-26-2012 05:48 PM
menance
12-22-2010 06:14 PM
BlackHHR
02-26-2007 07:42 AM
Quick Reply: Engine Diagrams
