HHR SS injector size
Old 01-18-2017, 08:28 PM
drspock's Avatar
I want to increase fuel. What is stock Injector # on the 2.0 Turbo and what is the next best step up without going overboard ? I have up pipe, down pipe, 9" filter, TrifectaTune, no Cats, and Stage 1 Cams soon to be installed.
drspock is offline
Old 01-19-2017, 07:41 AM
DrLoch's Avatar
You can contact ZZP https://zzperformance.com/ and talk to them.
There are a couple of different ways to increase the fueling. They (ZZP) offer larger Opel injectors but you may run out of HI pressure pump volume in which case ZZP also offers a cam with a larger HP pump lobe to provide additional fuel volume, Another way is to add a 5th injector to the intake manifold which will serve two purposes, One provide the added fuel for power added, two it helps keep the intake tract and valves from coking up. The case of that is the PCV system used on the LNF.
DrLoch is offline
Old 01-24-2017, 06:43 PM
Blue_SS's Avatar
THAT is awesome advice. ZZP is great, and if they have a fix (or fixes), go for it.
Blue_SS is offline
ssdivin
7
03-28-2011 08:43 AM
HHRthunder13
2.2L Performance Tech
07-18-2009 05:41 PM
K511Wilson
07-19-2007 12:57 PM
hookupny
06-11-2007 11:09 PM
poeg
03-07-2007 07:33 PM
Quick Reply: HHR SS injector size
