Intercooler
Old 01-26-2015, 07:23 PM
bherrick's Avatar
Intercooler
I've searched the forum looking for an upgraded intercooler to replace one that was damaged by a piece of a pallet kicked up by a semi and found that there isn't any current posts.
i'd like one that would be a direct replacement so a dealership body shop could handle the installation while they're doing the other needed work
Any thoughts would be much appreciated.
Thanks
-Bob
bherrick is offline
Old 01-26-2015, 08:20 PM
You say you want an upgraded intercooler but then you say you want a direct replacement. I'm a little confused by this.
Anyhow. There have been other threads and discussions about upgrading the stock intercooler.
Maybe try a Search using the term "aftermarket".
firemangeorge is offline
Old 01-26-2015, 08:28 PM
bherrick's Avatar
What I mean is I'd like an intercooler that a dealership body shop can install while they fix the rest of the damaged parts.
bherrick is offline
Old 01-26-2015, 08:38 PM
Either a stock one or aftermarket. I see no reason why the dealership couldn't do either one.
Now, there may be some extra labor charges incurred if you go with an aftermarket. Sometimes those need a little added labor time for "fitting".
Best thing is to ask the body shop that's doing the repairs.
Old 02-04-2015, 11:16 AM
racer-ray's Avatar
HHR SS OEM Intercooler
I have a stock intercooler removed @ ~ 30,000mi. from my 2009 HHR SS Automatic. Includes hotside pipe. Send me a PM w/offer.
I live in Granbury, TX.
Thanks, Ray.
racer-ray is offline
Old 02-05-2015, 04:44 PM
bherrick's Avatar
Thanks for the offer but I went with the ZZP.
bherrick is offline
Old 02-05-2015, 05:05 PM
black Tara's Avatar
good choice! I have a zzp ic myself. They do offer 2 one hangs down about a half inch lower than the oem cooler and one does not. you may want to consider the smaller one cuz it will be tucked away, and this problem may never happen again with the smaller IC. Also the dealership had no problem with the installation, they did a great job as well!
Tim
black Tara is offline
Old 02-06-2015, 05:30 AM
bherrick's Avatar
I bought the larger one, bigger I'd better! ;-)
bherrick is offline
racer-ray
12-18-2013 02:59 PM
BOBBY H
2.0L Performance Tech
10
03-05-2012 06:33 PM
RobSSTurbo
07-11-2011 11:29 AM
bartSS
49
03-22-2011 11:02 PM
Quick Reply: Intercooler
