Dual Pod A-Pillar
Old 09-29-2009, 04:28 PM
Canuck's Avatar
Dual Pod A-Pillar
Not a big fan of multi-pod A-pillars, think 3 pods is over the top but maybe two might be nice. Especially now that Areoforce has a twin gauge set-up, enabling us to run two off the same port. So I started to fabricate my own dual pod A-Pillar. I'm a long ways from finished but had to see what it looked like in the vehicle. As I said still lots of work yet to do, shape isn't quite perfect yet, so back to the grinder tonight. But it is coming along nicely. Process forces me into smoothing down the whole pillar as well - no more textured plastic (I couldn't duplicate that look), which means removing it from both pillars. Current look is in a rough primer and it doesn't look good but coming along well enough that I'm not embarrassed to share. Basic shape is there, I'll be taking it down so the gap, gauge to outer pod edge, is marginal as is the case with the original. Running 2 Areoforce gauges simultaneously is so cool, no more having to skimp on what I want to display. Need to take a picture of the driver's view - looks so much better, but you can't see the shape which is what I thought people would want to see.
Canuck is offline
Old 09-29-2009, 04:36 PM
NxlKing2304's Avatar
looks good so far, good job!
NxlKing2304 is offline
Old 09-29-2009, 04:40 PM
masterchief1112's Avatar
great job looks like its coming along well
masterchief1112 is offline
Old 09-29-2009, 04:57 PM
Father Azmodius's Avatar
I'm thinking of running two, and trying to mount them above the column on the gauge surround. How natural is the viewing position?
Father Azmodius is offline
Old 09-29-2009, 05:09 PM
asanti's Avatar
That's not bad! Kudos on the innovation. Let us see more once it's finished, then figure out how to mass produce them. I'll bet I'll be in line to get one from you.
Later
Allex
asanti is offline
Old 09-29-2009, 07:02 PM
Canuck's Avatar
I'm now back re-constructing the unit so unable to take more pictures, but the position off the add-on pod is very prominent, with the display far more visible than the existing boast gauge. The result of being higher and located, slightly to the right of the pillar.
Canuck is offline
Old 09-29-2009, 09:32 PM
xzombiex66's Avatar
nice job!!
xzombiex66 is offline
Old 10-05-2009, 08:55 PM
HHR_SS_QC's Avatar
I have a second Aeroforce gauge, waiting in it's box for a dual pod A-pillar. If you decide to mass produce the dual unit, count me in to buy one.
HHR_SS_QC is offline
Old 10-05-2009, 09:07 PM
*jerdog*'s Avatar
Nice work man, but what are you trying to display? I'm new to the turbo world and just thought I'd ask the dumb question. Really though..it looks cool!!!!
*jerdog* is offline
Old 10-06-2009, 08:23 AM
Canuck's Avatar
To tell ya the truth, I haven't yet decided. I believe I have the selection of something like 63 different items to monitor and with two gauges I can display 4 at a time and can set two alerts (i.e. over temperature, boast level, shift point, etc....). I'll set-up each monitor to cycle thru a different set of selection options, but just off the top of my head, I'd like to digitally display boast, temperature (water, oil, intake air?), mph (since I can't see the standard gauge), knock retard, HP, rpm - hmmm, I might need a third gauge
Should have pics of the finished product later this week, if I don't mess up the painting
Canuck is offline
Quick Reply: Dual Pod A-Pillar
