Problem after ignition switch recall
Had the recall completed on 2009 HHR had no problem with the turn switch not canceling when it went in. Picked it up know the switch doesn't cancel. What's going on? Fix one problem then create another.
Obviously they messed something up and you should take it back to let them make good.
Is there an actual question here?
May I direct you here: https://www.chevyhhr.net/forums/gm-recall-campaigns-70/
Well, I guess I just joined the party. My problem is a bit different though, the lock cylinder jammed before the dealer could pull the car out of the garage. The car will now be out of commission for 3 days, thankfully the dealer gave me a loaner.
firemangeorge
GM Recall Campaigns
06-23-2014 09:52 PM
