Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old 11-20-2015, 01:44 PM
  #581
bobojay's Avatar
Originally Posted by Oldblue
great job , now take a long scenic drive and grab a burger and a soda!!
We did after I finished
bobojay is offline
Old 11-20-2015, 01:49 PM
  #582
Awesome isn't it!
Oldblue is offline
Old 11-20-2015, 01:51 PM
  #583
bobojay's Avatar
I should have said, we did but substituted a couple beers instead of soda :)
bobojay is offline
Old 11-22-2015, 07:30 PM
  #584
grizzam's Avatar
wasn't paying attention to that little gray clip on the solenoid electrical connector. was praying it wouldn't break. didn't even know that it came out...lol. once i got them out, they snapped right on to the new ones. thought i had gottent he wrong part. wasted $54 getting a new one and they was the same part#. oh well, i have a spare now. but this thread helped out alot. plus i changed the air filter too. thanks for the post whooper and all that had positive input.
grizzam is offline
Old 11-22-2015, 08:14 PM
  #585
Yeah that connector is a tricky one. Glad it all worked out.
whopper is offline
Old 01-19-2016, 11:56 AM
  #586
Beefjerky's Avatar
Now i get a check engine light and car fumes from engine bay.
Excellent write up but what about the proper connections i think i hooked them up wrong and now i dont know which connector goes where?
Beefjerky is offline
Old 01-19-2016, 12:07 PM
  #587
The connectors are unique for each solenoid - check the first posting - scroll down thru the pictures and you will see a picture of the solenoids still in place, with the connectors disconnected. Hopefully you got the solenoids installed correctly: ie: the intake on the intake side and the exhaust on the exhaust side?
whopper is offline
Old 01-19-2016, 12:08 PM
  #588
bobojay's Avatar
On our 2009, 2.2, as the wires to the solenoids come out of the main harness, that's how they plug in. In other words, the one that comes out of the harness closest to the firewall plugs into the closest to the firewall placed solenoid.
Hope this helps....
bobojay is offline
Old 01-19-2016, 12:10 PM
  #589
x2!!!
whopper is offline
Old 01-19-2016, 02:44 PM
  #590
Beefjerky's Avatar
Thank you so much .GODBLESS YOU.
Quick Reply: Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
