Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
Old 01-19-2016, 02:46 PM
  #591
Beefjerky's Avatar
Thanks and godbless
Beefjerky is offline
Old 01-28-2016, 10:21 AM
  #592
jerry-hhr's Avatar
Talking Chev HHR 2009 - fail codes P0010 and P0011
Thank you for the posting of the fail codes P0010 and P0011.
The procedures and the P/N info is greatly appreciated
jerry-hhr is offline
Old 01-28-2016, 11:29 AM
  #593
aradmahogany's Avatar
Pretty simple and straight forward repair. This thread is actually what brought me to the forum a couple years ago!!!!!!
aradmahogany is offline
Old 02-01-2016, 08:12 PM
  #594
Ken TLE's Avatar
Thank you so much!
I just want to thank this site and everyone who post useful information! When my engine light came on I was suggested by someone to switch out the 'camshift sensor', but I'm glad to have stumbled here and to those who said "Intake/exhaust Solenids" instead. It was my first time working on my HHR and I truly don't know if I could have done it without this guide. Again, thank you, and I hope to work on my HHR with your help in the future!
Ken TLE is offline
Old 03-08-2016, 07:10 PM
  #595
DwRed2LT's Avatar
I had posted else where here on the forum for code P0010.
I was directed to this thread.
Thanks Whopper for the write up on this, and RJ_RS_SS_350 for the link.
I had the code pop just this morning. 56,600ish miles
Will be back with update. . . . . .
DwRed2LT is offline
Old 03-08-2016, 07:47 PM
  #596
You are most welcome. Let us know how it goes with the replacement.
whopper is offline
Old 03-25-2016, 10:45 AM
  #597
SMH2010SSHHR's Avatar
I don't know if this was mentioned in the previous 54 pages of posts but I was able to remove the exhaust CPASV (black top) without having to remove anything. I left it connected until I had it out to make it easier to get the connector off. Had it out and reinstalled in 15 minutes. I didn't try it but I think I could probably get the intake CPASV out too if I took the connector off first. I did blow out the pocket it sits in with 100 psi air first. I have a 2010 SS HHR.
SMH2010SSHHR is offline
Old 03-25-2016, 11:21 AM
  #598
Good tip that might help someone out. thanks.
whopper is offline
Old 03-29-2016, 06:52 AM
  #599
Andre508's Avatar
Hello all I have a 06 hhr and the t/c light cam on and it bangs into gear I changed the exhaust cam solenoid it still bangs into gear any suggestions
Andre508 is offline
Old 03-29-2016, 07:05 AM
  #600
Technical Moderator
What code? Could be the other one or something else. This is a 2.4L?
donbrew is offline
Quick Reply: Camshaft Position Actuator Solenoid Valve Replacement (w. pics) - P0010/11 P0013/14
