Door Lock Assembly Fix: Lots of Pics
Old 03-01-2017, 09:21 AM
  #31
Technical Moderator
My question: the ebay motors don't come with that gear. Is anyone aware of the success rate in removing/installing it onto the new motor?
See post #6.
donbrew is offline
Old 03-01-2017, 11:51 AM
  #32
JSK
JSK's Avatar
Thanks Blue - but after reading don's experience and having read post #6 here, I'm leaning towards buying the actuator (already found the part number in the "Part Number" sticky note) rather than spending so much time in repairing the present faulty actuator.
Thanks guys!
JSK is offline
Old 03-01-2017, 01:10 PM
  #33
It's a far better choice you've made! Not only less work, but less possibility of damaged parts and delays ordering more!
Oldblue is offline
Old 03-01-2017, 05:16 PM
  #34
JSK
JSK's Avatar
I agree...
...and i've lived and learned enough with THIS car to last the rest of my life. Heh.
Will update as progress/regress is made!
JSK is offline
Old 03-21-2017, 12:35 AM
  #35
JSK
JSK's Avatar
Quick update: yippeeeee, all my doors lock and unlock now! I used a weed-puller to get those panel-fixtures loose (NOT easy), and GMPartsDirect.com provided the part for something like $120. Thanks to all for this tutorial! Made the job possible at home.
(anyone want a broken Right Rear door lock actuator to rebuild? ...will send for cost of shipping)
JSK is offline
Old 04-27-2017, 11:56 PM
  #36
JSK
JSK's Avatar
dagNABBIT - a few weeks ago I noticed that the driver's side rear door lock stopped working. arrrrrrrrrrgh
maybe i'll use the old lock assy as a learning device and try the self-repair process described above...
JSK is offline
Old 05-02-2017, 06:10 PM
  #37
stanvalp's Avatar
cheap chinese crap. motor fails and jams the door lock. cant lock or unlock it. cant open the door. friggin dangerous if u ask me. cant exit vehicle in an emergency. gm should be held liable.
stanvalp is offline
Old 05-02-2017, 06:12 PM
  #38
stanvalp's Avatar
for now i removed the motor and plastic gears. at least it works manually for now. couldnt open the back door to get baby in car seat.
stanvalp is offline
Old 05-02-2017, 06:28 PM
  #39
Technical Moderator
Maybe something is jamming it?
donbrew is offline
Old 10-01-2017, 05:23 PM
  #40
JohnT's Avatar
Originally Posted by Sno White
The Jameco part number is different than what was in my Door Lock Assembly - one letter off. Of course I do not know if it makes any difference. Or if it is actually a better or worse motor - perhaps I or someone will look into if there is a better motor than GM used in this application.
The small gear is a tight press fit. I did not wish to possibly damage it with its removal from the old motor OR damage the gear upon installation on the new motor or possibly damaging the new motor during installation of the gear. That is why I went the route I did in buying the complete motor/gear assembly. Sometimes my hands have a way of destroying small parts.
I cannot find a motor with the gear attached. Can someone tell me if the gear can be removed from old motor a placed on new motor? Thanks JohnT
JohnT is offline
Quick Reply: Door Lock Assembly Fix: Lots of Pics
