Door Panel Removal
Old 03-27-2016, 08:16 AM
  #41
Pull the pin count to three and throw , oops that's for hand grenades.
It is a simple job, just need the right type of pliers.
Oldblue is offline
Old 04-22-2020, 07:23 PM
  #42
jjoverit's Avatar
Door panel retaining pin layout
Does anyone have a Door panel retaining pin layout? There are different sizes. I'm getting the kit. Just wanted to make sure it goes back together right. All 4 doors. I mixed them up
jjoverit is offline
Old 04-22-2020, 07:34 PM
  #43
I think Cat Man HHR has that info. I'll see if I can find it.
RJ_RS_SS_350 is offline
Old 04-22-2020, 07:40 PM
  #44
Here's 1 https://www.chevyhhr.net/forums/gene...e-61782/page2/
And another https://www.chevyhhr.net/forums/how-...ontacts-62119/
Old 07-16-2021, 01:37 PM
  #45
fairyterryz's Avatar
Originally Posted by GRUMPEE
slight hijack here,
ChevyMgr... The horizontal trim piece aobve the map packet - one of the "studs(?)" broke off. Do I have to replace the whole door panel or can I replace just the trim piece?
I used gorilla glue clear got at autozone for like 6-7 bucks. Followed directions and worked like a charm. All the attachments were broken off , so the glue worked , thank God!
fairyterryz is offline
Old 07-16-2021, 02:10 PM
  #46
Awesome, it works! Great that you got the strips to grip!
Oldblue is offline
Old 09-22-2021, 10:19 AM
  #47
For reinstalling the door panel, what the diagram doesn't show. The clips along the window edge, labelled #6 in the diagram. I could not get the door panel to clip into them tightly, it rattled around, came off. Turns out that there is another rib on the inside of the door panel, that hooks onto the clips. Not the outer edge of the door panel.
Old 09-22-2021, 10:28 AM
  #48
Good point, RJ
Oldblue is offline
Telemicus
10
04-13-2010 08:17 AM
txbass06
01-29-2010 09:54 AM
axoman912
13
02-08-2008 10:28 AM
Krusty
7
12-26-2007 01:03 PM
568rick
08-12-2007 05:16 PM
Quick Reply: Door Panel Removal
