Fix storage bin latch
Old 01-23-2015, 12:42 PM
RkyMtnHHR's Avatar
Well finally happened, the plastic on the bin latch broke. Tried to epoxy it back together with no luck. So I decided to spend a whole $2 to fix the problem. Went to local hardware store and got 2 each nylon nuts, bolts and washers. Drilled out the lid and fitted it all together.
And this is how it looks. I have the Dark Grey touch-up paint which is almost the exact same color.
RkyMtnHHR is offline
Old 01-23-2015, 12:44 PM
Lucky's Avatar
Nice work.
Lucky is offline
Old 01-23-2015, 01:18 PM
Welcome to the site ! Nice fix.
Oldblue is offline
Old 01-23-2015, 02:29 PM
Technical Moderator
I enlarged the pictures for you. If you use the method outlined in my sig they come out large.
donbrew is offline
Old 01-27-2015, 12:40 AM
JB Weld worked on mine, your fix looks good, but the left screw is not level in rotation to the other one.. That stuff would keep me awake at night..
sleeper is offline
HHRUNNR
09-27-2012 09:33 AM
GriffingR
12-31-2011 06:14 PM
txbass06
07-08-2009 08:10 AM
pitbull76
01-25-2009 04:38 PM
Seca650RJ
11-02-2008 12:02 AM
Quick Reply: Fix storage bin latch
