Headlight issue
Old 07-30-2011, 02:00 PM
mchuntley's Avatar
Headlight issue
I have a headlight out, but when I click the remote to get in the both headlights come on.. when I get home only one is on . So. When you click the remote, is it using the del or something?
This is 2007 hhr
Thanks,
Matt
mchuntley is offline
Old 07-30-2011, 02:24 PM
LawDog88's Avatar
low or high beam out?
LawDog88 is offline
Old 07-30-2011, 03:20 PM
Pretty sure you have a filament burned out on that side, check them manually with the stalk switch.
843de is offline
Old 07-30-2011, 10:50 PM
daddy2isaiah04's Avatar
I had the same problem. When you press the button on the remote, it lights up the high beam, but you have a low beam burnt out. Check them when they are on, and check both beams. One is burnt out, and the other is the one the button is lighting up.
daddy2isaiah04 is offline
Old 07-30-2011, 11:03 PM
Lucky's Avatar
x2
Lucky is offline
Oblena
02-11-2013 06:31 PM
mmont50
12-11-2012 05:49 AM
mmcd
12-09-2011 09:56 PM
RaceOn
10-17-2009 02:46 AM
Quick Reply: Headlight issue
