HHR clunk fix
If your "clunk" isn't coming from the bumper cover, check your sway bar end-links. Mine went bad at 20k miles, and now at 65k I need to do it again. I have yet to find links with grease zerks. The Dodge neon/PT had the same issue.
I see your up in Alaska but, you could not find these?
the new style has the zerks at an angle into the head of the link like in the above picture much easier to grease.
Your local parts palaces should have these or order up a pair from Amazon or EBAY
Moog K750012 are the correct length for the LS and LT suspension
Front Sway Bar Endlinks - Chevrolet HHR - MOOG-K750012
