HHR Rear Dome Light will not Work
I just bought a 2008 HR LS. The rear Dome Light would not work. I was going to try and replace the assembly, however discovered how hard it is to replace the assembly. The switch seemed loose, so I took the lens cover off the dome light. The switch lever fell out. I looked at it very closely and I discovered the metal contacts of the switch has a spring underneath it. It was stuck. I used some WD 40 on it and it came loose. Put it back together and it works well now.
Happy13178
05-14-2012 11:59 AM
