How to add GM Remote Start without option AP3
i want to do this, but i dont even know where to start
could someone point me in the right direction?
what i mean by that, is show me exactly what to do and where the BCM is please
i have an 08, i have the proper fob, i have the remote start option 'on' in the dashboard, and all i get is flashing lights
i think this mod will work for me
I ha the same. Just my ligths flashed. The BCM is at the front passenger seat. there is a panel to the left as you are facing front. It is where the fuses are. You must scrape the purple wire on pin 3 and attached a wire and groung it. It will then start.
this is pretty much what i was looking for
pics would be even more helpful, but i think i can get it from here
#26
My understanding is that manual tranny = no remote start. Think about it. Even the manual tells you to put it first and pull the e-brake when leaving unattended. How are you supposed to start it in gear?
#28
Ok. So can someone point out exactly which wire to ground? And where did you ground it to? Thanks!!
#29
The open connector with all the wires showing is not the right connector. Pin 3 of the connector that you can just barely see in the lower right of your picture is what needs grounding. Pick any of the screws holding the BCM for a ground.
#30
Does anyone know if this is possible on a 2007. The wiring harness appears to be different as there are four PU wires in the harness and none of them are in pin 3?
Thanks
Thanks
