HHR Rear Dome Light will not Work
Old 10-28-2014, 12:04 PM
lgaston1's Avatar
Smile HHR Rear Dome Light will not Work
I just bought a 2008 HR LS. The rear Dome Light would not work. I was going to try and replace the assembly, however discovered how hard it is to replace the assembly. The switch seemed loose, so I took the lens cover off the dome light. The switch lever fell out. I looked at it very closely and I discovered the metal contacts of the switch has a spring underneath it. It was stuck. I used some WD 40 on it and it came loose. Put it back together and it works well now.
lgaston1 is offline
Old 10-28-2014, 01:55 PM
Good fix. I've moved it to the "How-To" library where more might see your solution to the problem. :)
Big thanks for the contribution to the site.
whopper is offline
Old 10-29-2014, 11:54 AM
Technical Moderator
You are lucky, they usually get melted beyond recognition.
The actual fixture is held to the roof by a magnet. After you know that it comes off easily.
donbrew is offline
jejeni
09-27-2014 09:37 PM
Happy13178
05-14-2012 11:59 AM
twr4d
05-13-2009 01:13 PM
norcalmike
07-08-2008 11:29 PM
suburbanjunior
02-21-2008 12:12 PM
Quick Reply: HHR Rear Dome Light will not Work
