How To:Change Rear Wiper
Old 01-31-2012, 11:18 PM
There is a post on here somewhere, that tells ya which wiper blade to buy. Then cut in half, & have a spare blade...
Finding that post is another matter..
sleeper is offline
Old 01-31-2012, 11:20 PM
Or you can just pick up a Trico Exact Fit 11A at Advance Auto Parts for $11.98, pops right on with minimal fuss and bother.
843de is offline
Old 01-31-2012, 11:28 PM
My amputated arm is stuck behind the airless painter.
SS fan is offline
Old 02-01-2012, 04:30 PM
Technical Moderator
I've heard of one-armed paper hangers.
donbrew is offline
Old 02-03-2012, 11:18 AM
chuckkarate2's Avatar
Question removing cover on rear wiper arm
Can someone advise how to remove the cover over the rear wiper arm. I afraid of breaking it if I just pull on it. Any assitance would be much appreciated.
Kind Regards,
Chuck
chuckkarate2 is offline
Old 02-03-2012, 11:41 AM
  #26
db/sb's Avatar
Before you lift the wiper arm, gently pull up on the end of the cover closest to where the wiper arm pivots, it 'rolls' right off.
db/sb is offline
Old 02-03-2012, 02:13 PM
  #27
Question removing cover rear wiper are
db/sb thank you for your reply. I spread the cover and it seemed as if it was going to come off but I just couldn't get it, I was afraid if I put any more force on it the cover it was going to break the tabs. When I pulled up it seemed as though it was stuck on the rounded end. Any other suggestions would be appreciated.
Kind Regards
Chuck
Old 04-26-2013, 09:42 PM
  #28
normbal's Avatar
Zombie Post!
Damn. THIS is why I come back to this forum once - or twice - a year.
44k miles on a 2007 HHR just had all kinds of fluids changed, alignment, new tires, about $1200 worth of stuff and that rear wiper HAD to be replaced.
Went to Amazon dot com, $11.19 delivered (I'm a prime member), should be here by the 30th.
Thanks one and all.
normbal is offline
Old 04-27-2013, 08:59 AM
  #29
Thank You Abeg.
Blue Beast (aka Boydie) is offline
Old 04-27-2013, 04:46 PM
  #30
DwHhr2LT's Avatar
Thanks for the post on how to. . .
have had my Hhr almost 2 yrs
sure the blade needs replaced !
DwHhr2LT is offline
Quick Reply: How To:Change Rear Wiper
