The Tool I Use......
Old 02-10-2015, 03:27 PM
Blind Lizard sent me a PM and started me to thinking? Now don't go running for cover,
I thought it would be a cool idea to share our tools, we use to get the job done!
In this case I use this trim tool from HF to remove the Baby Moon hubcaps on my WV rally rims without chipping the powder coating. I bought it in a set for under $10 bucks.
Now if anybody has a particular tool for a specific job then post a picture and brief description, where you bought it or if you made it.
Oldblue is offline
Old 02-11-2015, 02:45 PM
Blue_SS's Avatar
SWEET IDEA. Pls proceed!
Blue_SS is offline
Old 02-11-2015, 06:33 PM
skyline26's Avatar
skyline26 is offline
Old 02-11-2015, 07:10 PM
db/sb's Avatar
Well, he has a Ford Ranger.....he need all of those tools (see signature)
db/sb is offline
Old 02-11-2015, 07:28 PM
I see this isn't going anywhere, fast ! Two of you didn't post pictures!!
Oldblue is offline
Old 02-12-2015, 03:57 AM
Lucky's Avatar
Here is a cool tool I found on ebay.
It used to remove inner tie rod ends. It made quick work of removing and installing the tie rod end.
Lucky is offline
Old 02-12-2015, 04:12 AM
Lucky's Avatar
Here is another picture of the tool in action.
It work with a cam type action to grab the inner tie rod.
Lucky is offline
Old 04-27-2022, 08:34 AM
Radco's Avatar
Tools !
It is always nice having the right tool for the job.
On my car I had to change the speakers like many of you !
As you know the door panels are pop in !
I do have trim tools but the clip pliers tool looked like a good idea .
And not a every day tool so cheap at HF sounded good lol
For a cheap HF tool seems well made and it works ! and for 9$ not out much.
If it was a daily tool then I would buy a better brand , But these seem well made !
I was also told it can help remove trim molding in the house !
FYI it is a good idea to file down the edges of the tool as it is not real smooth and could scratch paint !
So far that is my only complaint about it !
And yes the bar type tools work but a good excuse to ad more tools to the tool box lol
What tools did you get and said I should have got them sooner lol
https://www.harborfreight.com/panel-...p+removal+tool
Radco is offline
Old 04-27-2022, 12:21 PM
mongo's Avatar
Harbor Freight transmission jack. Beats wrestling with a transmission.
https://www.harborfreight.com/450-lb...ack-61232.html
mongo is offline
Old 04-27-2022, 02:11 PM
There, moved as discussed Rich, and made it a sticky.
Oldblue is offline
Quick Reply: The Tool I Use......
