License Plate Lights Replacement Help
Old 08-28-2008, 06:45 PM
Stingeralt10's Avatar
I looked around on this site, and I havn't seen anyone mention it. I noticed the other day that there are two tiny light bulbs near the rear hatch door opener that light up the liscene plate (i assume. Ha, im never beind my car whiel its running).
So my question is does anyone know how to remove them, or waht size they are for a possible replacement. I was thinking some blue lights would accent the plate nicely. THANKS!
Stingeralt10 is offline
Old 08-28-2008, 07:40 PM
dandhcomputers's Avatar
License Plate Lamp
To replace one of these bulbs, do the following:
1. Remove the two screws holding each of
the license plate lamps to the fascia.
2. Turn and pull the license plate lamp forward
through the fascia opening.3. Turn the bulb socket counterclockwise and
pull the bulb straight out of the socket.
4. Install the new bulb.
5. Reverse Steps 1 through 3 to reinstall the license plate lamp.
Page#334
Owner Manual
Sylvania Bulb: Long Life
Part Number: 194LL
dandhcomputers is offline
Old 08-28-2008, 08:34 PM
tcstoy's Avatar
Check your state laws first. Most if not all states require the tag lights to be white. Just want to save you from getting pulled over.
tcstoy is offline
Old 08-28-2008, 08:45 PM
Thank you! Sorry I dont have an owners manual. thanks for the information
Old 08-28-2008, 09:59 PM
https://www.mygmlink.com/pdf/go2cont...et/2006hhr.pdf
This a link for the 2006 Chevrolet HHR Owner Manual it is a pdf file just open it and save it to you computer
I hope this helps out
Old 08-28-2008, 10:41 PM
ymerej_mortsdnil's Avatar
Thumbs up 'hyper white'
I put a set of the 'hyper white' bulbs in from Pep Boys...they give a very nice glow to the plate, a much nicer look than the stock yellowish colored bulb. This is the first mod I do on every car I buy...I don't know if they are legal, but I haven't been pulled over in the many years I have been using them on my rides!
ymerej_mortsdnil is offline
Old 08-28-2008, 11:08 PM
xzombiex66's Avatar
LED reverse and license plate lights from Ebay/
xzombiex66 is offline
Old 08-29-2008, 03:14 AM
MrVette's Avatar
I used the same LED's as Chad. They have a nice blue tint to them and very easy to install.
MrVette is offline
Old 08-29-2008, 03:18 AM
MrVette's Avatar
Here's a link to the Ebay seller...
http://cgi.ebay.com/ebaymotors/2006-...spagenameZWDVW
MrVette is offline
Old 08-29-2008, 07:36 AM
Vinny's Avatar
I went with orange LED from eBay, takes about 10 minutes including putting the tools away
Vinny is offline
Quick Reply: License Plate Lights Replacement Help
