How to remove shifter handle automatic.
Old 05-20-2008, 09:58 PM
jameswattsjr's Avatar
I need to know if the factory automatic shifter can be removed and replaced, if it can be removed please advise how. Thank's
jameswattsjr is offline
Old 05-20-2008, 10:43 PM
ChevyMgr's Avatar
If you mean that shifter knob, here is the procedure.
2007 Chevrolet HHR | HHR (VIN A) Service Manual | Transmission/Transaxle | Automatic Transaxle - 4T45-E | Repair Instructions - On Vehicle | Document ID: 1664350
Floor Shift Control Knob Replacement
Removal Procedure
Important: Place the shift control in NEUTRAL before attempting to remove the shift knob screw.
Name:  shift hndl 1.jpg
Pull the shift knob bezel (1) down to expose the shift knob retaining screw.
Name:  shift hndl 2.jpg
Remove the shift knob retaining screw (1).
Name:  shift hndl 3.jpg
Remove the shift knob (1) and bezel (2) from the shift control lever.
Installation Procedure
Important: Place the shift control in NEUTRAL before attempting to install the shift knob screw.
Name:  shift hndl 4.jpg
Install the bezel (2) and shift knob (1) to the shift control lever.
Name:  shift hndl 5.jpg
Install the shift knob retaining screw (1).
Tighten the screw to 2 N·m (18 lb in).
Secure the shift knob bezel (1) to the shift knob.
ChevyMgr is offline
Old 05-21-2008, 10:26 AM
Thank's for the info. That saved me from breaking something.
Old 07-03-2008, 10:15 PM
edb
edb's Avatar
how can I remove the piece of plastics surrounding the shifter lever? I mean the one with shift indicator, not the chrome ring.
Thanks.
edb is offline
Old 07-04-2008, 08:47 AM
ChevyMgr's Avatar
xTooltipElement
Service Information
2007 Chevrolet HHR | HHR (VIN A) Service Manual | Document ID: 1737081
Console Shift Lever Bezel Replacement
Name:  Shift Plate.gif
Callout Component Name
1 Front Floor Console Assembly
Refer to Front Floor Console Replacement .
2 Console Shift Bezel
Tip:
The Console shift bezel is replaceable on cars equipped with automatic transmissions. Cars equipped with manual transmissions the bezel is not serviceable. The shifter bezel and front floor console plate must be removed as one assembly. The console shift bezel retainers must be released from the underside of the console upper trim plate.
ChevyMgr is offline
Old 07-04-2008, 09:34 AM
edb
edb's Avatar
thanks chevymgr.
That's a heck of job, I guess I have to skip it.
edb is offline
Old 07-06-2008, 04:55 PM
Stingeralt10's Avatar
I have an automatic. Will any automatic shift knob work with the HHR, or are there specific ones. How do I know if they are compatable? Thanks...
Stingeralt10 is offline
Old 09-05-2008, 04:24 PM
ecl
ecl's Avatar
Originally Posted by ChevyMgr
xTooltipElement
Service Information
Attachment 3272
Refer to Front Floor Console Replacement ..
How do get that piece out? Does it just pop off like the chrome bezel been trying to figure this out but afraid I might break it.
ecl is offline
Old 09-18-2008, 05:00 PM
cruzdreamer's Avatar
I want to change mine too some day...
I want to get the cool flame ball shifter for automatics....it lights up...great info here and I hope I can do that one I get it and I am hoping it will be compatible...here's the website http://www.flameball.com/HomePage.htm?src=overture
cruzdreamer is offline
Old 10-10-2008, 03:37 PM
One note on this, which is great and a BIG help............
I found that you have to actually turn the chrome post one half turn to be able to lower it to get to the retaining screw. This was also the case for the leather boot on the new model.
GDZHHR is offline
Quick Reply: How to remove shifter handle automatic.
