How to repair flex pipe
Old 03-21-2014, 10:51 PM
Originally Posted by ilikepie
does changing the pipe from the rubber accordian type to the metal type like that work?
No rubber in the OEM flex joint, that part of the exhaust sees temps ranging from 800-1200 degrees Fahrenheit during engine operation. Any rubber would melt or burn away in mere minutes.
The big difference in the OEM part and the aftermarket part is price as pointed out earlier in this thread. Going the aftermarket route will save you hundreds of dollars over dealer pricing.
P.S. to the forum!
843de is offline
Old 03-22-2014, 01:06 PM
Fox Hat's Avatar
Thats not rubber!!! rubber will melt
Its a metal accordian so it can expand and contract.
Metal doesn't like that so it eventually cracks.
This is one of those not if but WHEN repairs.
Fox Hat is offline
Old 12-21-2015, 01:02 PM
Kellywren's Avatar
Thank you for the info. Good job
I too was told by dealership last week that it was not covered.
A shop here quoted me $140 installed but with their own pipe conversion. He'd just replaced the same thing last week on a Cobalt.
Kellywren is offline
Old 12-21-2015, 01:10 PM
Not sure of your mileage, but it is covered under the 8/80 emissions warranty.
For more info: https://www.chevyhhr.net/forums/prob...ex-pipe-42365/
whopper is offline
Old 12-21-2015, 01:35 PM
When my original flex pipe cracked , on vacation, in South Carolina, I ordered up a new down pipe, it included the gaskets, new flex pipe and catalytic converter, and bolts $165.00.
5 bolts, two O2 sensors and about 3/4 of an hour and all fixed!
Oldblue is offline
Old 02-23-2016, 08:59 AM
  #26
henchmaniii's Avatar
MY 06 has had this problem twice now. First time it happened was about 2 years ago and was covered under my extended warranty. Cost me $100.00 dollars. (Was never told by the dealer that it would have been covered under the emissions warranty). The issue has now resurfaced and I'm on my own for paying for the repair. A friend of mine can get me the replacement flex flange from the dealer for the "good guy" price of $760.00 dollars. The list price is over $1100.00 dollars! Going to try the fix recommended by bad ass bowtie. Definitely cheaper than the dealer.
henchmaniii is offline
Old 02-23-2016, 09:09 AM
  #27
Welcome to the site! This is for cut and weld or clamp
Amazon.com: Chevrolet HHR Cobalt Saturn Ion Front Flex Section Exhaust Pipe 2.2 2.4 W/gasket: Automotive Amazon.com: Chevrolet HHR Cobalt Saturn Ion Front Flex Section Exhaust Pipe 2.2 2.4 W/gasket: Automotive
And this replaces the whole pipe
http://m.ebay.com/itm/New-Catalytic-Converter-Chevy-Ion-Chevrolet-Cobalt-HHR-Saturn-Ion-1-5YR-WARRANTY-/350910338426?nav=SEARCH
Just some options
Oldblue is offline
Old 02-23-2016, 09:40 AM
  #28
Technical Moderator
That is the price for the entire cat! A new flex can be had on eBay for less than $80. Oh, and have someone inspect your motor and transmission mounts, that's the usual reason for repeat failures.
Direct Flex Repair Pipe JGM2143L 3LBF CO2 02 09 Chevrolet HHR 4 Cyl 2 2L 2 4L | eBay
donbrew is offline
Old 02-23-2016, 09:43 AM
  #29
Yep another eBay link to explore. The dealer version is way to much money!
Oldblue is offline
Old 02-23-2016, 10:38 AM
  #30
db/sb's Avatar
This will only fit 02-09 Chevrolet HHR 4 Cylinder 2.2L 2.4L
db/sb is offline
Quick Reply: How to repair flex pipe
