New Key, How to program it.
Old 04-07-2007, 09:21 AM
TomsHHR's Avatar
Location: Superior, WI - Over the Hill Warranty Club member
TomsHHR Tip Thread!!!!
To program a new key.
1. insert your present key, start and shut off the engine.
2. remove key.
3. insert new key within 30 seconds and turn on the ignition.
4. wait 10 seconds, then start your engine.
Your new key should now be programmed.
I bought 2 extra keys after I got my HHR and keep one in my travel bag for that "OOPS Moment" when somehow the TSA loses your keys for you.
TomsHHR is offline
Old 04-07-2007, 10:44 AM
dbarberaz's Avatar
Make this a sticky and remame it "Toms Tip Thread"
dbarberaz is offline
Old 05-24-2007, 07:23 AM
auburnskydive's Avatar
Thanx for the tip on programming key. Mine just suddenly quit working and this saved me from spending vacation time going to the dealership to have it done. Thanx, again!
auburnskydive is offline
Old 05-24-2007, 08:32 AM
This is great info, thanks Tom!
GDZHHR is offline
Old 05-28-2007, 04:41 PM
whitelotus9's Avatar
When using one of the programmed keys to unlock the vehicle, is the horn supposed to start beeping at a slow rate? Mine does and it's most annoying. I haven't found anything in the owner's manual that addresses this yet to enable me to silence the horn beeps when using a programmed key. Thanks...
whitelotus9 is offline
Old 05-28-2007, 04:55 PM
Yes, if you're using the key to manually unlock the door, the horn will sound until you either insert the key in the ignition or deactivate the alarm with the remote.
jx3 is offline
Old 05-28-2007, 05:11 PM
TomsHHR's Avatar
I found this to be true if your fob does not work. I found if you lock the last door with the key, you could open it and no alarm went off.
And it was a rental HHR this happened on.
TomsHHR is offline
Old 05-29-2008, 09:13 PM
TomsHHR's Avatar
the famous How-to-program your key
TomsHHR is offline
Old 05-30-2008, 09:32 AM
Gremlin's Avatar
Excellent info, thank you. The manual/users guide that came with Auggie is as big as a novel and just as hard to find this type of info in it.
Gremlin is offline
Old 05-30-2008, 10:03 AM
ChevyMgr's Avatar
The reason for this, is the alarm is only armed by using the fob or the electric lock switch.
So in essence if you use the key or push the lock down manually, the alarm is not on.
ChevyMgr is offline
Quick Reply: New Key, How to program it.
