Rear Shock How-to
#32
Fireman-
Glad you mentioned that, I only removed the lower shock bolts also for spring swap..
But do remember wiping a bit of grease on the bolt shoulders & loctite on the threads.
If mine didn't have shouldered bolts, I would have dug up some that did.
Now I'm curious about the top bolts..
#34
Just wanted to jump in and drop a line here that this job was, by far, the EASIEST thing I have ever done to a car. Easier than changing oil. If anyone in the future is searching on here about his particular subject debating if they should do it or not I say GO FOR IT. Impact wrench made the job 30X easier, though. When putting the bolts back in make sure to HAND TIGHTEN them first so as to not cross thread. I took both old ones out at the same time and they were so far gone they wouldn't come back from being compressed. They still haven't after four days XD
#39
Does anybody know the length of the stock shock compressed and then fully extended? I have the leveling springs on my car and had to use shorter shocks (otherwise the coil springs would fall out when the car was jacked up). My shocks need to be replaced and I forgot which one I had used. Or better still, does anybody know which short shocks work?
Thanks
Thanks
