removing automatic gear shifter
Old 12-25-2009, 02:56 PM
capp002's Avatar
hey everyone, i have two 2009 chevy hhrs one has a leather shifter knob on it and my other hhr has a plastic one how do you remove the shifter knob. it has a leather shifter boot please help
capp002 is offline
Old 12-25-2009, 06:55 PM
an08HHR's Avatar
This thd is for an 07 but should be the same or very close for you to get the job done. Here is the thd on it https://www.chevyhhr.net/forums/show...t=shifter+knob
an08HHR is offline
Old 12-25-2009, 07:38 PM
capp002's Avatar
i found that post ive been on here most of the day looking . i have the2009 which has the boot if you push the boot down theres a plastic spacer but set screw anyone know how to remove this shifter(automatic) thanks
capp002 is offline
Old 12-25-2009, 08:20 PM
an08HHR's Avatar
Forgot the 09 was different. There have been a couple guys that put the 09 unit in their older HHRs. Bet they know how to switch the knob but not many posting today being a holiday and those with families aren't worried about the forum right now. Bet one of them will post in a day or so.
With luck Brad (ChevyMgr) will post a pic on "how to" since he has all that info at dealership
an08HHR is offline
Old 12-25-2009, 10:14 PM
djr1973's Avatar
I know on my 08, you have to pry the chrome sleave downwards to get to the set screw. I dont know if it is the same for the 09 though.
djr1973 is offline
Old 12-27-2009, 06:20 PM
rharrison's Avatar
Thumbs up 09 shifter
I just did mine today I have an 07 panel and put on 09 leather boot on The 09 has a black plastic ring under the knob just give the black ring a 1/2 turn and it will drop then you can see the allen screw that has to be turned out almost all the way. I didn't like the chrome on the 09 knob so I put the knob from the 07 back on the new shifter. I am going to change the complete shifter assembly in the spring when the weather warms up because I don't have a heated garage.
rharrison is offline
Old 12-31-2009, 07:36 PM
capp002's Avatar
THANKS HARRISON THAT WAS A BIG HELP
capp002 is offline
Old 01-06-2010, 07:46 PM
rharrison's Avatar
Talking 09 shifter
No problem I have gotten lots of help from others Love the clean look of the new shifter
rainmanva
08-12-2013 06:47 PM
roadblock69
Drivetrain (Excluding Engine)
13
01-16-2012 02:45 PM
MetallicaMatt
07-07-2009 07:00 PM
Velocity12
04-16-2007 07:39 AM
Quick Reply: removing automatic gear shifter
