Removing the inside door panel - Chevy HHR Network
Reply
LinkBack Thread Tools Search this Thread
Old 02-07-2009, 03:52 PM   #1
orangutanHHR's Avatar
Images: 20
Has any member ever removed the insde front door panel? If so please l take a few minutes and tell me how so I do not break anything. Thank members.
orangutanHHR is offline   Reply With Quote
Old 02-07-2009, 03:55 PM   #2
Images: 8
HillsdaleHHR is offline   Reply With Quote
Old 02-07-2009, 03:56 PM   #3
Images: 774
There is a thread or two..................
Basically there are two screws at the bottom of the door pull under the rubber insert, and one more in behind the cap behand the door handle. One pin on the door jam section the you push in to take out. Then just grab and pull around the lower edges. You will need to then disonnect the handle and switched to remove completely.
GDZHHR is offline   Reply With Quote
Old 02-08-2009, 08:56 AM   #4
Images: 20
You guys are great. That is why this works for all of us. Thanks again.
Old 02-19-2009, 06:00 PM   #5
Images: 10
After you take it out is there any way to swap out the center section? I was thinking about changing the center to black(my panels are gray).
wagoneer is offline   Reply With Quote
Old 02-19-2009, 06:51 PM   #6
The part that threw me the first time I removed the door panel was the little clip on the rear facing part of the door at armrest level. The center part pushes IN which releases the clip assembly part so it can be removed. when you reinstall you pull that part so it is sticking up and push it flush to lock it. It makes more sense when you see it.
dbfruth is offline   Reply With Quote
Old 02-20-2009, 12:11 AM   #7
Images: 89
the part i never got was how to unhook the handle...i had bear of a time trying to figure it out, and gave up lol.
Yonash is offline   Reply With Quote
Old 03-05-2009, 11:48 PM   #8
Both the front seat interior door handles have broken on my daughter's 2006 HHR.
Now I get to try and remove them so I can manufacture a repair. This is the only post I have seen about removing the interior door panel. Thanks
snakedoctor62 is offline   Reply With Quote
Old 03-11-2009, 02:39 AM   #9
Broken, as in cracked down the middle?
If that is it, I have the same problem. How do you think you want to fix it?
matt
mchuntley is offline   Reply With Quote
Old 05-29-2013, 02:45 PM   #10
I got the damn inside door panel off, but when I put it back on, it's all loose and wiggly. I can't get the snaps around the perimeter to go back in. It's tight where the metal clips are up by the window, and of course where the screws are holding it into place (by the handle), but around the perimeter it just kinda hangs there.
edgarfrog is offline   Reply With Quote
Reply
Thread Thread Starter Forum Replies Last Post
inside door panel insert artfx1 Commonly Used Part Numbers 4 09-17-2014 03:39 PM
Removing drivers power window control panel from door? pstar Problems/Service/Repairs 2 06-09-2014 07:14 PM
Panel - Inside Rear Door Pulls - Anyone installed them? SlickRick2 Mods - Interior 9 09-26-2012 06:40 PM
1-15850555 l/inside door panel w/handle forest3670 Inactive Classified Ads 0 11-11-2011 01:02 PM
need help--removing door panels GDZHHR General HHR 6 10-02-2006 05:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright © 2005 - 2013 Internet Brands, Inc. All rights reserved.
