Turn Signal Canceling Failure Fix: Lots of Pics
#51
Brilliant! Thank you for the great write up and pictures.
After playing for a couple minutes to get one part right, it went together with the spring going the right way and works like a champ.
I love this forum.
I love this forum.
#52
I'm so glad I found this thread!
Mine went out last weekend, right after my husband replaced the clockspring. Naturally, I assumed he accidentally broke it; as I had accidentally broken the clockspring. (Apparently, turning a disconnected steering wheel around and around is not a good idea. Woops!)
Anyways, I'm going to try to fix it tomorrow. It seems like a very simple fix for such an annoying problem.
& my husband will be happy to save a few bucks as well!
#53
Mine is broken...
First off kudos to all of you who posted about how to do this fix.
Mine did not work at all so I removed it this morning in just a few minutes knowing how from this thread. After reversing my spring I noticed the cam plate would not center and that's when I discovered that the cam plate had broken.
so I'll have to hunt one down, maybe Junkyard or a non OEM.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#55
ACDelco D6254E GM Original Equipment Turn Signal and Headlamp Dimmer Switch
$27.11 to my door in two days.
#58
Many years ago, when I swapped my steering wheel for a smaller one, I recall a piece on the left side of the hub falling off. Ever since, my lights don't cancel. But I have learned to prefer it this way. They used to shut off when I turned the wheel a little to change lanes before making a turn, and once I forgot to put the signal back on and got pulled over.
Now, I turn them off when I want to. And, there is a feature on our cars that will notify you if you leave the turn signal on too long.
#60
My '07 HHR with 113K miles finally had the dreaded turn signal cancel fail. How great is it to already know the problem & solution because we belong to the best car forum anywhere!
I did order a new one from Rock Auto less than $30 delivered. Just finished replacing it after looking at Snowhites pic's, took less an an hour. I will now repair the old one for a spare.
Thanks again to CHEVHHR.NETsaved me big money & a trip to the dealer.
